AutoCAD Civil 3D General Discussion
Active Member
jleftwich
Message 1 of 6 (61 Views)
Creating Contour Labels
61 Views, 5 Replies
02-09-2005 08:31 AM
I am trying to create contour lines from polylines for mineral geological mapping. Can I even do this or is there something more complex I have to do. I need someone to help me walk through the steps. Thank you
*Landman
Message 2 of 6 (61 Views)
Re: Creating Contour Labels
02-09-2005 12:40 PM in reply to: jleftwich
Choose to create a surface (Right click on surface in the prospector box) then choose > Definition > Contours and then choose your polylines. Hope that Helps. "jleftwich" wrote in message news:31041454.1107966701988.JavaMail.jive@jiveforum1.autodesk.com... > I am trying to create contour lines from polylines for mineral geological mapping. Can I even do this or is there something more complex I have to do. I need someone to help me walk through the steps. Thank you
Active Member
jleftwich
Message 3 of 6 (61 Views)
02-10-2005 09:02 AM in reply to: jleftwich
I think I still am doing something wrong or I am not following you. You go to civil>surface>new surface. Is that correct. When I do that it just brings up a box with nothing in it. I know I must be missing a step somewhere. I am using ac3dmap. I could email you my contours if you don't mind help me. I have another question how can I find the area between these two contour lines (polylines). I appreciate any help.
Active Member
jleftwich
Message 4 of 6 (61 Views)
02-10-2005 12:14 PM in reply to: jleftwich
*wfb
Message 5 of 6 (61 Views)
02-11-2005 06:02 AM in reply to: jleftwich
"j" , I am beginning to believe that you are not using Civil3D, but Map 3D. You are in the wrong newsgroup. Please correct me if I am wrong. Bill "jleftwich" wrote in message news:31041454.1107966701988.JavaMail.jive@jiveforum1.autodesk.com... > I am trying to create contour lines from polylines for mineral geological mapping. Can I even do this or is there something more complex I have to do. I need someone to help me walk through the steps. Thank you
Active Member
jleftwich
Message 6 of 6 (61 Views)
02-11-2005 07:22 AM in reply to: jleftwich
yes it is map 3d sorry for the mistake.
Post to the Community
New Post
Need installation help?
