Civil 3D Forum
Creating CL Points from Profile
5 REPLIES 5
d_reno
473 Views, 5 Replies
hey,
I need to extract centerline elevations from a finished CL profile. From reading other topics here it seems the way to do this is by extracting COGO points from the corridor model along the CL. This isn't really what I need, but I can create an ASCII file from the points and pull the elevation data in a spread sheet. But, is there a better way? And, what I would really like is to also extract the station value for each CL point. If I create an alignment label style that shows the elevation and station, can I then extract this label data to get it into a spreadsheet or ASCII file?
To summarize - I want to pull finished CL elevation with its station from a corridor or profile and be able to import this data into a spreadsheet.
I am using C3D release 2011, Win 7, capable machine, everything up to date.
THANKS.
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
5 REPLIES 5
Jeff_M
in reply to: d_reno
Why not use the Incremental Stationing profile report? It will save the station and profile elevation directly to an Excel file.
d_reno
in reply to: Jeff_M
Thanks Jeff,
Why not indeed? Thanks for the advice.
dr
David Renaud, RLS
d_reno
in reply to: d_reno
Well, that creates an XML file. Profiles_in_CSV creates an Excel file, but it doesn't create what I select/deselect. Still, if I want stationing the solution seems to be in a report, so I will keep plodding away. Is it possible to create custom reports without getting into code?
thanks again.
David Renaud, RLS
Jeff_M
in reply to: d_reno
It creates an XLS file for me....Excel Spreadsheet, which opens in Excel,
d_reno
in reply to: Jeff_M
Yep, my mistake. I didn't look close enough when I checked out files of type. As it is I copied/pasted into Excel and it placed the data into cells so I am off and running.
thanks for your help.
David Renaud, RLS
Rail Community
