This may be a stupid question, but how do I create subassembly groups on an existing assembly? Also, is it possible to move subassemblies between groups if they're already placed on the assembly? Thanks in advance!
Solved by sboon. Go to Solution.
If you attach a subassembly to the baseline it will create a new group. Yes, you can move subs from one group to another. Simply select one, right-click and use the move to command from the shortcut menu.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Just what do you mean by create "Subassembly Group"?
Don Ireland
Engineering Design Technician
