Civil 3D Forum
Creating a surface from a surface
3 REPLIES 3
darreng_oa
317 Views, 3 Replies
i need to create a sub-set surface from my main surface. not sure what the vernacular is for a "subset surface" in c3d but i do have a feature line that bouinds the desired area, but that is as far as i can solve.
i did try creating a new surface - pasted the main surface in the edit definition, then deleted triangles until the boundary alighned wiht my featureline.  This seemed to work, but  when i view the properties of the smaller subset suface, it shows a mimum and maximum elevation that is incorrect.
any ideas?
3 REPLIES 3
rendarin
in reply to: darreng_oa
Uhh, instead of a feature line you can just make it a 2D polyline and add it as a Boundary.
neilyj666
not sure about the elevation issue - did you add the feature line to the surface definition?
As the previous poster said add a 2d poly as sn outer boundary
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
david.zavislan
Try the Create Cropped Surface command.  The command is located in the expanded Surface Tools ribbon panel on the modify surface or contextual surface ribbon tabs.
David Zavislan, P.E. | Wood Rodgers, Inc.
Rail Community
