Corridor Properties > Surfaces tab. Click the "Create new surface" button. Give it a style, specify the code you want your surface to represent (probably Top), click the "+" button to add that code to your surface, click OK, and you're done. If you need a boundary, there is a Boundary tab, too.
Which data types do you generally add? I have a pretty generic situation: 13' lanes, curb & gutter, daylight to existing topo. Add as breakline for each?
Typically you would use links as surface breaklines. Generally none of the longitudinal features are necessary.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
