Hi!
I need to create a surface that is the elevation difference between 2 surfaces, i.e. at a particular x,y location if the elevation of surface A is 47' amd the elevation of surface B is 42', the new surface will be 5' at that location.
Is this possible? And if so, please explain how?
THANK YOU VERY MUCH!
Go to the prospector and right-click surfaces, create a new surface. Under the "type" in the upper left hand corner of the pop-up should be an option to create a "TIN volume surface." The window will then prompt you to enter a base and comparison surface.
Yes, this would be a completely new surface. The spot elevations of this surface would give you the vertical cut/fill at any given location.
neilyj (No connection with Autodesk other than using the products in the real world)
