Civil 3D Forum
Creating a specific contour on a surface....
8 REPLIES 8
Message 1 of 9
mmcmanus
2524 Views, 8 Replies
  I am using Civil 3D 2011 and wondering how to create just one contour on an existing surface at a specific elevation. I need to show where floodwaters would get to at a specific elevation so that contour would be the easiest way if I can contour the surface with just 1 elevation. I don't want to have to create 0.1' contours all over the site and then remove all the extras.
Any ideas?
8 REPLIES 8
Message 2 of 9
neilyj666
in reply to: mmcmanus
This can be achieved easily using User Defined Contours - can't explain further as not in front of C3D but googling or using C3D help should point you in the right direction e.g. http://newsletters.hagerman.com/newsletters/ebul88-CIVIL.htm
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 9
scottn
Did you find a way to make this work? I'm trying to do the same.
Message 4 of 9
mmcmanus
Yes, The user defined elevation worked fine. I don't have C3D open now so I can't relay the exact steps but go through help and it will explain it. You can use 1 elevation or a range as needed.
Message 5 of 9
Alfred.NESWADBA
in reply to: scottn
the point is to create a user-specified contour in the dtm-opens (plus activation of visibility in the surface-style)
...and that's what the above item links to.
What's not working for you?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 9
scottn
Actually have a much quicker solution..Just have to extract objects from a surface.
Message 7 of 9
Alfred.NESWADBA
in reply to: scottn
What objects do you extract if you don't have any object on a specific height?
E.g. if you have contours every 1m, but you want to have a specific contour at 239.762m, any "extract objects from surface" will not help as long as you don't have a userspecific contour at this elevation.
- alfred -
Alfred NESWADBA
Message 8 of 9
scottn
in reply to: Alfred.NESWADBA
Didn't need elevation to the nearest 1/1000 of a meter! In this case I need to nearest foot. Regardless set your contour interval say to nearest 10th and extract required contour elevation. It can be 5', 1', or 1/10 intervatal. Doesn't matter, change your interval, extract required object, change interval back. Very quick!
Message 9 of 9
mathewkol
User-defined contours are quicker and they're dynamic. For future reference.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
