Distinguished Contributor
mmcmanus
Message 1 of 9 (984 Views)
Creating a specific contour on a surface....
984 Views, 8 Replies
03-04-2012 02:42 AM
  I am using Civil 3D 2011 and wondering how to create just one contour on an existing surface at a specific elevation. I need to show where floodwaters would get to at a specific elevation so that contour would be the easiest way if I can contour the surface with just 1 elevation. I don't want to have to create 0.1' contours all over the site and then remove all the extras.
Any ideas?
neilyj
Message 2 of 9 (975 Views)
Re: Creating a specific contour on a surface....
03-04-2012 04:54 AM in reply to: mmcmanus
This can be achieved easily using User Defined Contours - can't explain further as not in front of C3D but googling or using C3D help should point you in the right direction e.g. http://newsletters.hagerman.com/newsletters/ebul88-CIVIL.htm
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Member
scottn
Message 3 of 9 (896 Views)
04-09-2012 09:58 AM in reply to: mmcmanus
Did you find a way to make this work? I'm trying to do the same.
mmcmanus
Message 4 of 9 (892 Views)
04-09-2012 10:01 AM in reply to: mmcmanus
Yes, The user defined elevation worked fine. I don't have C3D open now so I can't relay the exact steps but go through help and it will explain it. You can use 1 elevation or a range as needed.
Alfred.NESWADBA
Message 5 of 9 (891 Views)
04-09-2012 10:01 AM in reply to: scottn
the point is to create a user-specified contour in the dtm-opens (plus activation of visibility in the surface-style)
...and that's what the above item links to.
What's not working for you?
- alfred -
Alfred NESWADBA
Member
scottn
Message 6 of 9 (880 Views)
04-09-2012 12:00 PM in reply to: mmcmanus
Actually have a much quicker solution..Just have to extract objects from a surface.
Alfred.NESWADBA
Message 7 of 9 (876 Views)
04-09-2012 12:06 PM in reply to: scottn
What objects do you extract if you don't have any object on a specific height?
E.g. if you have contours every 1m, but you want to have a specific contour at 239.762m, any "extract objects from surface" will not help as long as you don't have a userspecific contour at this elevation.
- alfred -
Alfred NESWADBA
Member
scottn
Message 8 of 9 (872 Views)
04-09-2012 12:19 PM in reply to: Alfred.NESWADBA
Didn't need elevation to the nearest 1/1000 of a meter! In this case I need to nearest foot. Regardless set your contour interval say to nearest 10th and extract required contour elevation. It can be 5', 1', or 1/10 intervatal. Doesn't matter, change your interval, extract required object, change interval back. Very quick!
mathewk
Message 9 of 9 (846 Views)
04-10-2012 08:24 AM in reply to: mmcmanus
User-defined contours are quicker and they're dynamic. For future reference.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
