Civil 3D Forum
Creating a smooth TIN surface
16 REPLIES 16
Message 1 of 17
wilsonm2000
3123 Views, 16 Replies
Hi guys
Been chatting with an architect in my office, and he was asking me if we could make our TIN surfaces smooth.  I cannot find a way, would it take a 3rd party program?  He wants it like the image i attached.  Any ideas on how to achieve this with a TIN surface?
16 REPLIES 16
Message 2 of 17
AllenJessup
in reply to: wilsonm2000
You can't totally smooth a Surface and have it remain a Civil 3D Surface. You can however make it smoother by using the AeccSmoothSurface command. This will add point to the surface to make it appear smother.
You might be able to explode a copy of the surface and somehow make the 3D faces into an AutoCAD Surface and do something with that. But I've never tried that since the result would be for display only and not linked to anything in Civil 3D.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 17
wilsonm2000
in reply to: AllenJessup
I dont need it to stay as a Civil 3D surface, its for visual, not to design with. 🙂
Message 4 of 17
AllenJessup
You could try:
Click Output tab > Export panel > Export to Civil View for 3ds Max Design. Then use the 3DSin command to bring it back in as a Mesh. Pretty much a guess but if you play with it you might get what you want.
That would only work if you had 3DS Max Design.
Allen
Allen Jessup
Message 5 of 17
wilsonm2000
Hi, I cannot work out the dialogue box for that.  It looks like it can only export corridors?  Can you please explain step by step after you click on the Output tab > Export panel > Export to Civil View for 3ds Max Design ...............  What next?  Thanks
Message 6 of 17
Jeff_M
Help says: "Feature lines, corridor, surface, and point data can be exported with Export to Civil View for 3ds Max Design."The left side of the dialog has items you can check to include in the export. If you have a surface it will be listed. If not using corridors, ignore the right side of the dialog.
Note, I have never used this until just now so I don't know how this will look in 3ds Max
Message 7 of 17
AllenJessup
OK. Here's what I've come up with.
Copy your surface. Set the surface to display triangles I'd then suggest smoothing the surface. Then explode the surface twice to get 3DFaces. Use the CONVTOSURFACE command to convert the individual 3DFaces to mesh surfaces. Then use UNION to make them all one mesh. Finally use MESHSMOOTH to smooth it further. Say yes anytime it warns you about primitive solids.
That's about the best I can come up with without in depth study and trial.
Allen
Allen Jessup
Tags (1)
Message 8 of 17
Joe-Bouza
@AllenJessup wrote:
You could try:
Allen
Hence the the old saying : "All Contours are lies"Smiley Wink
Joe Bouza
Message 9 of 17
wilsonm2000
in reply to: Joe-Bouza
When I Export to Civil View for 3ds Max Design, it saves it as a  .vsp3d file, but when I do 3DSin command, it only lets me use .3ds file types.....
Message 10 of 17
antoniovinci
As already said by Allen: "That would only work if you had 3DS Max Design"...
Message 11 of 17
wilsonm2000
I do have 3DS Max Design, hence the fact I was able to click on Export it to 3DSMax Smiley Wink
Message 12 of 17
antoniovinci
Did you try to load the .vsp3d file in 3DS Max Design, saving then as .3DS classic for Autocad..?
Message 13 of 17
wilsonm2000
in reply to: antoniovinci
Nice one, cheers, thats the step that was missing 🙂
Message 14 of 17
wilsonm2000
Ok, opened 3DS Max Design, and I cannot find a way to load the .vsp3d file.
Message 15 of 17
wilsonm2000
Its ok, found Civil View 😛
Message 16 of 17
antoniovinci
I have no 3DS Max to simulate your scenario, however it's odd, that you can "Export to Civil View for 3ds Max Design" but this latter cannot handle the resulting file.
Maybe would you post this issue in the 3DS Autodesk forum..?
Message 17 of 17
wilsonm2000
I was just trying to open the file, but you need to use the Civil View extension to import that kind of file.  Which I have now done, and works
Rail Community
