The engineers at my company digitize proposed contours in a drawing and then they want me to create a surface out of the contours....the contours usually are 2 foot contours with areas that the software tends to translate based on the contours that I selected to create the surface.....I then usually need to create a profile, which does not look accurate compared to the contours, such as low spots etc...............my question is since the engineers at my work do not how to use the software, and I am not an engineer, making the profile look a certain way sometimes needs to be tweeked by me....any suggestions as to how to alter the proposed surface? Hopefully someone else can relate to this question and has any suggestions. I am pretty sure that feature lines cannot cross contours that I have selected to create the surface?
Have you seen and tried the suggestions on Brian Hailey's blog for creating surfaces from contours?
Joe Bouza
Joe Bouza
