The profiles i usually create for street p&p and storm p&p are 30 scale (horiz) and exaggerated at 6 (vert 1=6, .5=3, etc). The storm p&p varies by scale depending on how ling it is. When creating a profile in the new autocad what scale the profile? is it according to the scale you set for the sheet? Also, is it exaggerated? The style of template it uses for the profiles can it be changed?
1. In Tool Space, go to Settings Tab
2. open "Profile View"
3. open "Profile View Styles",
4. select the style you are going to use, right click it, select edit.
5. This will open the "Profile View Styles" editor window,
6. then click the "Graph Tab"
7. this is where you can change your Vertical Exaggeration.
