I am designing a retention pond in an existing surface. I set the base of the pond and execute the grading at the desired slope and it generates the pond just fine, with the exception of rounded corners. I need the corners to be square, mitered corners instead of the round. Is that possible? And how?
I'm using Civil 3D 2013.
Solved by neilyj666. Go to Solution.
ahhh. So no D-9 onsite, only teaspoons and butter knives
Joe Bouza
