Wondering, why is Z coordinate ignored while creating pipes in edit network mode by snapping to 3d points?
neilyj (No connection with Autodesk other than using the products in the real world)
You're snapping to a node. If your points are displaying at elevation 0, which is typical, then you need to use the transparent Point Object ('PO) command to snap to the point at its z elevation.
Sorry, I did not understand using 'PO option.
The nodes (autocad points) have z value other than 0, there are no civil points initially. I would like to snap to autocad nodes (acad points, 3dpolyline vertexes, line endpoints etc) to get the pipe elevation from those points. Is it not possible?
@Anonymous wrote:You're snapping to a node. If your points are displaying at elevation 0, which is typical, then you need to use the transparent Point Object ('PO) command to snap to the point at its z elevation.
