Civil 3D Forum
creating a pipe snapping to 3d points
5 REPLIES 5
robert06
316 Views, 5 Replies
Wondering, why is Z coordinate ignored  while creating pipes in edit network mode by snapping to 3d points?
5 REPLIES 5
robert06
in reply to: robert06
a screencast illustrating the problem
View Creating pipes by snapping to 3d points now.
neilyj666
What is your OSNAPZ set to? Try it =0
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
KirkNoonan
You're snapping to a node. If your points are displaying at elevation 0, which is typical, then you need to use the transparent Point Object ('PO) command to snap to the point at its z elevation.
robert06
in reply to: neilyj666
Neilyj, Osnapz is 0
robert06
in reply to: KirkNoonan
Sorry, I did not understand using 'PO option.
The nodes (autocad points) have z value other than 0, there are no civil points initially. I would like to snap to autocad nodes (acad points, 3dpolyline vertexes, line endpoints etc) to get the pipe elevation from those points. Is it not possible?
Rail Community
