Civil 3D Forum
Creating a pipe network from a feature line...
5 REPLIES 5
dgordon
1028 Views, 5 Replies
No matter what i set the default structure settings to, I cannot get the structures to come in with a sump that is not 2 feet when creating a pipe network from a feature line.  It's as if this command ignores the rules of the default structure.
can anyone else creating a pipe network from a feature line and get the sump to come in as zero?
I may post this to the wish area if i can determine this is a known unchangeable setting.
creating structures by layout doesn't count since I have been able to do this successfully.
I was developing a great idea for a workflow for placing initial design of a Sanitary Sewer, and this issue cropped up.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
5 REPLIES 5
Jeff_M
in reply to: dgordon
I am seeing this same issue in 2012. This should be reported as a bug/defect, not a wishlist item.
Jeff_M, also a frequent Swamper
ccoles
in reply to: Jeff_M
Sump depth can be set in the structure rules to zero. It is now in all my rules, and structures now come in at zero depth.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
ccoles
in reply to: ccoles
Also, you can set the rule, then apply them to your structures after the fact.
Windows 7 64-bit
Civil 3D 2013
Jeff_M
in reply to: ccoles
My structure rules are all set at zero depth. These rules are ignored when creating a network from a featureline. Yes, they can be fairly easily changed after-the-fact, but the key is, if there is a default rule set, it should be used and not ignored.
jmayo-EE
I have not been able to get this to work since the 08 release. I have done a few networks from objects in each release since with the same results as the OP and rules setting the sump to zero.
John Mayo
Rail Community
