I am trying desperately to create a corridor in C3D 2013.
I have the requisite Alignment, Profile and Assembly, yet when I create the corridor, either nothing appears, or it creates the corridor at incorrect elevations. I have the proper elevations in my alignment.
Any help would be greatly appreciated.
Could you post the drawing?
Check the properties of the Corridor and ensure it's using your profile and assembly.
Elevations in my Alignment? no.
You must have assigned the wrong "profile" in the corridor parameters dialog. Go back to the corridor dialog and check "ALL" of your targets.
Your Name
Your Name
Your corridor has nothing defining it. Before you add anything, though, you need the following:
The alignment needs a profile to define it's vertical location.
Once the profile is established, select the corridor in Propsector, right-click and select Properties. On the Parameters tab, choose Add Baseline. Select your alignmnet and profile. Next, add Region, accept the defaults for the entire alignment, or enter the range you desire. You will be propmted for the Assembly to use, choose the correct one.
