Civil 3D Forum
Creating a 3D Solid by using "LOFT"
5 REPLIES 5
2150 Views, 5 Replies
I have a terrain survey of an area, composed of:
POLYLINEs - contours with  co-planer points.
3D POLYLINEs - contours/breaklines with non co-planer points.
I want to create a single 3D Solid by using all of them. (So I can see and "feel" the topography of the area)
I read about "LOFT" command and tried to use it.
The problem is that in the list of "Objects That Can Be Used as Cross Sections"  - 3D POLYLINEs are not found.
Does anyone can help me with this? Is there another method of building a 3D Solid?
Also, another problem I have with "LOFT" is that some of the POLYLINES are open and some close,
and I understand that I can't use "LOFT" with both, only with one kind at a time.
Is there a way of solving this also?
* I use CIVIL3D 2007 (unfortunately...don't have a newer version)
Thanks a lot,
S_G_I
5 REPLIES 5
antoniovinci
Well, don't use LOFT but just create your surface by contours, then explode it down to 3Dfaces, then _EXTRUDE all.
Thank you very much for your help.
I changed the display settings so I can see the triangles, exploded this Tin surface and got 3D faces.
When I try to use "extrude", I'm asked to specify distance and direction.
However, all these 3D faces are already situated at their true location and I don't want to change it. (Also each one has a different height so I can't extrude more than one at a time).
I want to create a solid/smooth surface (with shadows to indicate hieghts) from these triangles.
What can I do?
Thanks again,
S_G_I
Sinc
In your Surface Style, turn on the "Elevations" in the "Display" tab.  You may also want to adjust the settings in your Surface Style -> Analysis -> Elevations, or go into your Surface Properties and adjust the ranges on the Anlysis tab there.
This should apply an appropriate color to each TIN triangle.
Sinc
antoniovinci
You won't change anything, here's the step-by-step process.
Assuming you wanna solidify your surface for 250 drawing units in low direction:
1] _EXTRUDE
2] select your 3Dfaces
3] _D
4] 0,0,0
5] 0,0,-250
Since the extrusion involves a lot of memory consumption, first you would practice with a small subset of 3Dfaces.
Sinc and Antoniovinci,
Thank you very much for your explanations and advice.
I will try to do as you suggest.
S_G_I
Rail Community
