Civil 3D Forum
Created Sheet does not show Vertical Alignment data (Line and Curves)
5 REPLIES 5
bozoli
539 Views, 5 Replies
Hi everyone.
i  have an issue in with my created sheets that does not show vertical alignment data. everything on the bands shows up nicely but the lines, curves and labels profile are missin.
see the attached image. you can notice from the image that there is no a signle data..
your help is much appreciated.
thanx
5 REPLIES 5
Jeff_M
in reply to: bozoli
Without seeing your drawing, here's a shot in the dark... use the DISPLAY command, then enter P for properties, then D for drawing. Scroll down to the Profile line and be sure the boxes for Model and Plan are checked.
If that's not it, you may need to post or email the drawing.
Jeff_M, also a frequent Swamper
bozoli
in reply to: Jeff_M
hi Jeff,
i have went through your suggestion and all my boxes are ticked, but the problem is not solved.
the drawing is too big to upload. maybe let me email you the drawing.
regards
Silver
Jeff_M
in reply to: bozoli
You can email me direct at jeffm AT quuxsoft DOT com although a better option may be to use a Dropbox account and give a link to it.
troma
in reply to: bozoli
Have you tried:
Check the profile style is turned on?
All layers on and thawed?
REGENALL?
Close the drawing and reopen?
Recover the drawing?
Audit the drawing?
Close the program and start it again?
Shut down the machine and reboot?
Mark Green
Working on Civil 3D in Canada
bozoli
in reply to: troma
Hi Guys,
i now think i know what the problem is, even if i donnot know the solution to it. the problem is i get this when my Profile View have other alignment superimposed. Because when i delete the superimposed profile and creating sheets, then it works fine, but when i create sheets with superimposed profiles, then it gives me this problem.
Does anyone know how can i get my left and right offset level that has a different road widths without the option of superimposed profiles?
regards
Rail Community
