Civil 3D Forum
create volumes surfaces with multiple boundaries
5 REPLIES 5
F.Camargo
698 Views, 5 Replies
Hi guys,
I'm trying to create volume from multiple boundaries.
In my projetc I have about 6 area and I wanna know that volume from the each area.
How Can I do that?
Add Boundary in Dashboard Volume I couldn't do that.
Thank in advance
5 REPLIES 5
ksorsby
in reply to: F.Camargo
Use SHOW and HIDE boundaries.
Kevin
F.Camargo
in reply to: ksorsby
I had to created many surfaces to calculate the volumes.
Is it correct?
ksorsby
Yes. If each AREA calculates the volume between TERRANO NATURAL and TERRANO PREOJETO then this is fine and will give you volumes for each area.
If you wanted, you could use HIDE and SHOW boundaries to give you a single volume for all those areas combined, ie. 1 giant volume for the two TERRANO surfaces then add HIDE/SHOW boundaries to clip the volumes only within those AREA's.
Probably wouldn't do that in this example though, stick to what you've already done.
Kevin
F.Camargo
Thank you,
I'm beginner in autocad civil and I don't know much about calculate the volume.
I'm happy If I'm doing the right thing.
Thank you
F.Camargo
Hi guys,
I don't wanna create othe post, because that post will help me explain my task. 🙂
I'd like to know the areas of the fill and cut. How can I do that?
The autocad give both areas right?
But I really need to know cut and fill area.
Thank in advance
Rail Community
