Civil 3D Forum
Create View Frames at 500 Feet
18 REPLIES 18
Message 1 of 19
ToddRogers-WPM
641 Views, 18 Replies
No matter what I try, settings I change, or different scenarios, the software will not place 500 feet on a sheet.  It will only do 400 feet.  Is there anyway to force this?
Todd Rogers
18 REPLIES 18
Message 2 of 19
jmayo-EE
in reply to: ToddRogers-WPM
Hey TIm. Isn't this controlled by the viewport size in the page setup template and the drawing scale?
John Mayo
Message 3 of 19
ToddRogers-WPM
in reply to: jmayo-EE
I thought it was.  I have created a max size viewport, but using 1:20, will not cut a 500 foot view frame for nothing.
Todd Rogers
Message 4 of 19
Todd, using 2012 I have an 11x17 sheet, 50 scale and my viewframes are 600'. Same thing in 2015, so my vp scale, etc. are working as expected.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 5 of 19
jmayo-EE
Can you post the file?
John Mayo
Message 6 of 19
ToddRogers-WPM
It's the OOTB Arch D 20 scale template file.
Todd Rogers
Message 7 of 19
Which version?
Lisa Pohlmeyer
Civil 3D User
Message 8 of 19
2010-2015
Todd Rogers
Message 9 of 19
ToddRogers-WPM
I know for a fact that I can get 500 foot per sheet.  The customer has 30 sheets that look like this...
It will not ONLY create these every 400 foot.  Why has there never been an option to specify how many feet per sheet?
Todd Rogers
Message 10 of 19
jmayo-EE
Did the customer apply a value for the match line repositioning when they created the sheets (third page of the wizard)? Perhaps the match lines were moved to these stations?
John Mayo
Message 11 of 19
ToddRogers-WPM
Yes sir.  Snap match lines down to the nearest was set as well.  Repositioning is set to 100.  I also tried setting the repositioning to 0, still cuts them every 400 foot at 20 scale.
Todd Rogers
Message 12 of 19
I'm using the Civil Imperial template, set vframe to start 25' before the alignment, set increment to nearest 10' with a 25' overlap for repositioning.  I get 500' vframes.
Lisa Pohlmeyer
Civil 3D User
Message 13 of 19
At 20 scale?
Todd Rogers
Message 14 of 19
yessir
Lisa Pohlmeyer
Civil 3D User
Message 15 of 19
Let me try those settings and see what I get.  Stay tuned....
Todd Rogers
Message 16 of 19
Thank you Lisa.  I have been doing this for 22 years, and I promise you, I learn something EVERY day!
Todd Rogers
Message 17 of 19
Yep, me too! C3D since the 2005 version, and I'm still learning. I love it when I learn something!
Lisa Pohlmeyer
Civil 3D User
Message 18 of 19
jporter
Intersting!  I had a client this week with the exact same request. The only way I was able to figure this out was to manually change everything (unlock the viewport, manually adjust the viewscale, edit the matchlines, adjust the profile view extents).  I don't think there is any other way.  Of course, I'd love for one of you to prove me wrong here.
Jason Porter
ASTI Civil Solutions Technical Advisor
www.asti.com
Message 19 of 19
jporter
in reply to: jporter
Of course if would have read the second page of the post then I would have seen that Lisa did find a way.  She always does.  Way to go, Lisa!
Jason Porter
www.asti.com
Rail Community
