Civil 3D Forum
Create Surface from 3D data
2 REPLIES 2
s_hutchison
739 Views, 2 Replies
I am working in Civils 3D 2014 and I have a survey with points already on the correct elevation layer, I have tried creating a surface from this but it does not show up.
My process:
I create a new drawing and insert a block (my topo survey) and click explode when I do this
- I create the surface by TIN and make sure I have the correct layer for the points that I am selecting
- Click ok
- Then go into that surface and turn on all layers and refresh - still nothing
- I also made sure that my surface style was 1m contours so I would definately see this
Any ideas?  I am very new to all this!
Sam
2 REPLIES 2
AllenJessup
in reply to: s_hutchison
Do you have a TXT or CSV file of the points? If so you can import them as Cogo Points or attach the file to your Surface.
If not you'll have to create the Surface from Drawing Objects and select the point blocks.
Allen Jessup
Allen Jessup
CAD Manager - Designer
gccdaemon
in reply to: AllenJessup
Or you can throw your hands in the air scream at the computer, quit your job and relocate to Sri Lanka. Although the previous statement sounds a little less problematic. Have a great Halloween!
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
