Civil 3D Forum
Create Sheets Dialog Box cut off
7 REPLIES 7
Message 1 of 8
apence
321 Views, 7 Replies
Using C3D 2009 with a 30" flat panel. The create sheets dialog box in the Plan Production Tools has the right side of the box cut off. Several of the buttons are in the cut off section - so I cannot use the buttons. Very annoying!
I have tried to expand the box. It makes the text entry boxes wider, but it doesn't show the buttons. I know there should be buttons, because some of the buttons are only partially cut off (and usable), and because there used to be buttons there in 2008. I have also tried changing the resolution on the monitor.
Anyone have an idea what is up. Is there a setting I can change to fix this? I am using a Radeon HD 3650 video card and Samsung SyncMaster 305T with windows XP Pro - if that helps.
7 REPLIES 7
Message 2 of 8
in reply to: apence
Have you tried changing your screen resolution?
Message 3 of 8
apence
in reply to: apence
Yes, I have tried that.
Message 4 of 8
in reply to: apence
One of my monitors is the same size as yours and should be run at 2560 x
1600. I suspect you have it set to a 4:3 ratio screen instead of something
like 16:9.
What resolution is it set at?
Bill
wrote in message news:6022499@discussion.autodesk.com...
Message 5 of 8
apence
in reply to: apence
It is set at 2560 x 1600.
Message 6 of 8
in reply to: apence
Well, that doesn't appear to be the problem. Perhaps you need to run a
repair of the installation through the Control Panel.
Bill
wrote in message news:6022531@discussion.autodesk.com...
Message 7 of 8
rj_1967
in reply to: apence
What was your resolution to this problem I am having the same issue.
Thank You
Message 8 of 8
K.A.Burns8PQVE
in reply to: apence
I am having the same issue and nothing seems to solve it.
I have had to turn my screen % so low that it is now hard to read the writing. This has solved the text going beyond the cut off point on the dialog boxes but not in all.
Please see attached image.
Rail Community
