Active Contributor
0 Kudos
Post 1 of 4
Create Pressure Pipe Parts
1166 Views, 3 Replies
05-21-2013 02:39 PM
I'm currently using the "Pressure Pipe" app in Civil 3D. The thing is, I need to create pipes that are smaller than 100mm (that's the smallest pipe in the catalogue). Specifically, I need 50mm and 75mm diameter pipes, parts and accesories. How can I create them?
Thanks in advance.
Look for this file on your system (if you are using 2013, look in the appropriate location):
"C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Civil 3D API\Part Publishing Wizard\PartPublishingWizardUsersGuide.docx"
23 Kudos
Post 2 of 4
Re: Create Pressure Pipe Parts
05-21-2013 06:45 PM in reply to: alegonb88
From Windows:
Start > All Programs > AutoCAD Civil 3D 2013 > Content Catalog Editor
Mike
Mike Caruso
Autodesk Certified Instructor - Civil 3D Autodesk Certified Professional 2014, 2015
www.civil3d.guru
Rockin' Civil 3D 2015 on a 13-inch MacBook Air | Intel i5 | 4GB RAM | 128GB SSD | Intel HD5000
266 Kudos
Post 3 of 4
05-21-2013 08:18 PM in reply to: alegonb88
Brian Hailey
CAD-1.com
My Blog
Active Contributor
0 Kudos
Post 4 of 4
05-22-2013 07:55 AM in reply to: BrianHailey
Funny the fact that its a WORD document! Perfect, looks like it isn't so simple but I should be able to create the parts I want from now on, thank you very much Brian.
