The create points tool window doesn't use the Points Creation options I set for Default Elevation and Description, when go to create a bunch of points I have to key these in for each one. I know if I go and set these in the settings tab they will stick, but I would like for the tool window to work like it implies.
Solved by Jay_B. Go to Solution.
What specific method are you using to create these points?
As an example Points>Create Points Miscellaneous>Manual>Brings up the Create Points dialog.
In the dialog if Parameter>Points Creation:
Default Elevation = 900
Default Description = Test
Prompt for Elevations = Automatic
Prompt for Descriptions = Automatic
Then click away and the Elev remains at "900" & the Desc at "Test".
If the Prompt values are set to "Manual" then they the user prompts appear @ command line.
to get default point and point label styles to stay you must make these changes first
Thanks Jay. I didn't realize there was a setting for the promts to be manual or automatic.
