Civil 3D Forum
Create points tool window doesn't obey defaults
3 REPLIES 3
IanMcClain
283 Views, 3 Replies
The create points tool window doesn't use the Points Creation options I set for Default Elevation and Description, when go to create a bunch of points I have to key these in for each one. I know if I go and set these in the settings tab they will stick, but I would like for the tool window to work like it implies.
Ian McClain
3 REPLIES 3
Jay_B
in reply to: IanMcClain
What specific method are you using to create these points?
As an example Points>Create Points Miscellaneous>Manual>Brings up the Create Points dialog.
In the dialog if Parameter>Points Creation:
Default Elevation = 900
Default Description = Test
Prompt for Elevations = Automatic
Prompt for Descriptions = Automatic
Then click away and the Elev remains at "900" & the Desc at "Test".
If the Prompt values are set to "Manual" then they the user prompts appear @ command line.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
caddie99
to get default point and point label styles to stay you must make these changes first
IanMcClain
in reply to: Jay_B
Thanks Jay. I didn't realize there was a setting for the promts to be manual or automatic.
Ian McClain
Rail Community
