I am running into a particular problem that has be befuddled. For some reason on one of my drawings, the "Next Point Number" dialog will not change to the next available point after I create some points. In other words if I go to create some points and it says the next point number is 5000, it creates the points, say 10 of them from 5000 to 5009, but the dialog still says the next point number is 5000.
The result of this is the program will not create ANY points until I go back in and manually tell it to start with the next available number. I'm only getting this in one drawing. The other drawings are fine.
Did I screw up a setting or something? Or is this a glitch? I woiuld attach the file, but it is 10MB+.
