Civil 3D Forum
Create point from a polyline
4 REPLIES 4
rvandever21
291 Views, 4 Replies
I want to create points from the polyline to identify in the field. For example, I create a square for a concrete pad and I want to identify the corners of the pad.
4 REPLIES 4
rl_jackson
in reply to: rvandever21
Point - Create Point on Object
Rick Jackson
Survey CAD Technician VI
rvandever21
in reply to: rl_jackson
Where is the option located?
Jay_B
Check out the Home Tab>Points>Create Points Miscellaneous>Polyline Vertices - Automatic option.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
ccoles
On the ribbon, under the 'Home' tab, second panel, Create Ground Data, Points, Create Points - Miscellaneous, Polyline Vertices
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Rail Community
