I want to create points from the polyline to identify in the field. For example, I create a square for a concrete pad and I want to identify the corners of the pad.
Solved by ccoles. Go to Solution.
Solved by Jay_B. Go to Solution.
Rick Jackson
Survey CAD Technician VI
Check out the Home Tab>Points>Create Points Miscellaneous>Polyline Vertices - Automatic option.
On the ribbon, under the 'Home' tab, second panel, Create Ground Data, Points, Create Points - Miscellaneous, Polyline Vertices
