All I want to do is draw a basic line, and when I hit the icon, why does the whole pull down menu open? Why cant it be like the circle command, where if you want to draw a simple circle and I hit the icon it goes into the command, and then if I want options I hit the arrow to the right side of the icon and the pull down menu opens up. Annoying!!!
Because it's a Civil 3D menu and there are many ways to draw a line in Civil. The first choice Create Line is what you want. It wouldn't make sense to have it default to Create line the way the Circle defaults to Center, Radius since Civil 3D is about Surveying and Civil Engineering. As mentioned you can type Line at the command line or crate a one or two key alias. You can also switch to to the Drafting and Annotation Workspace where the Line icon works the way you want.
Allen
Allen Jessup
CAD Manager - Designer
Thanks Jeff!!! Exactly what I was looking to do. Works perfect now.
Thanks to all for your responses!
