Hi Doug,
What release version of Civil 3D are you using? Different releases have different abilities when it comes to projecting to profile views.
Hi Doug,
The options for creating a style with a hatch or solid for objects that are projected to section views is [still] not available in Civil 3D.
I was able to use the projected object boundary as a hatch selection boundary [see below], but these hatches will be static, and would need to be manually moved/recreated in the projected object move. Of course, I only used an extruded cube to create and project a 3D solid. Your projected objects may not allow for that type of hatch boundary selection.
