Civil 3D Forum
Create Featureline From Alignment -- PROBLEM
3 REPLIES 3
doni49
239 Views, 3 Replies
I have an alignment that is 1877ft long.  I created a surface profile along the entire thing.  Then I used the Create Featureline From Alignment command to generate a featureline.  The resulting featureline that is listed in Toolspace is 0.04ft long and does not show up ANYWHERE in my drawing.  Just to confirm this last part, I created a new featureline style with a NEW layer assigned to that style (so there wouldn't be anything else on the layer).  Then I used the filter command to search for everything on that layer.  It didn't find anything.
What would cause this?
I'm using C3D 2012.
TIA!
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
3 REPLIES 3
doni49
in reply to: doni49
Ok.  I've found the featureline in my drawing but I'm still puzzled as to what's going on.  The alignment was originally created from a closed polyline.
The featureline goes from just shy of the END of the alignment (station 18+69.996) to the begining of the alignment (station 0+00).
What I'm trying to accomplish:  I want a featureline that is "draped" to the existing surface and I want it to be dynamically linked.  If the horizontal position changes, I want the elevations to update automatcally.
I know that I can create a featureline and use the "Elevations From Surface" tool.  But that's not dynamic (as best I can tell) and it only gets the elevations at the vertices.  I'd like for it to truly follow the ground line.
Don Ireland
Joe-Bouza
in reply to: doni49
open the closed pline a tiny bit before creating the alignment (although I done it with closed and did not have the issue you describe)
Alignment>> surface profile, FL from alignment>> pick the surface profile.
This work excidedly well for parking lot grading using a control surface
You will have issues if the surface does not completlet cove the alignment. Same with layout profiles; not even 0.01 ft shy.
Joe Bouza
doni49
in reply to: Joe-Bouza
When I zoomed in really, really extremely close, 🙂 I found that the ends were actually overlapping and this pline was NOT closed (but the original one from which this was offset WAS and IS closed).
So I fixed the overlap and closed it then recreated everything (alignment, profile and FL).  It's working now.
Don Ireland
Rail Community
