Civil 3D Forum
Create feature line by snapping to cogo point "node"
4 REPLIES 4
rkmcswain
3082 Views, 4 Replies
I think this issue started with SP2. I don't remember having these issues in SP1 and earlier.
Can anyone verify?
  1. Create some COGO points at varying elevations.
  2. Start a new feature line.
  3. Use "node" object snap and pick your first cogo point
  4. It does not pick up the elevation of the point (it used to)
  5. Now draw feature line segments to a few more cogo points entering the elevation each time.
  6. It does not pick up the elevation of the point (it used to)
  7. Now switch to Arc mode and snap to a few more cogo points.
  8. It does correctly picks up the elevation of the cogo points (like it used to)
4 REPLIES 4
tcorey
in reply to: rkmcswain
Randy, you're talking about Civil 3D 2013 with service pack 2? It works correclty for me.
Are you sure your point style has 3d geometry set to Use Point Elevation?
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
rkmcswain
in reply to: tcorey
Tim
(1) Yes, might help if I were to specify the version..... (2013 SP2)
(2) Yes, the points are "at elevation"
(3) This morning, it's working as expected. I should have waited before posting. Guess it was a fluke that needed a reboot to correct...?
Thanks!
LyleHardin
We had the same problem.
I found out that if you pick on the center of the COGO point snapping to NODE gives you an elevation of 0 (Zero).
If you snap to the outer portion of the COGO point node (nearer to the ends of the cross or outer portion of the circle or trianlge or however the point is defined) using the NODE osnap, it will give you the elevation of the COGO point.
So, in summary:
Snap to the middle of the COGO point yields an elevation of 0.
Snap to the outer portion of the COGO point will yield its elevation.
Also, for what it's worth, snapping to the INSERT of the text of the COGO point will also give the elevation, but it won't be on the X,Y point of the NODE of that point.
tcorey
in reply to: LyleHardin
So, in summary:
I sure can't get that behavior. The only thing I can get is the point elevation if the point style is set to use point elevations and 0 if the point style is set to flatten to elevation 0. I would love to see a drawing in which you can get the behavior you describe...
Tim
Tim Corey
Redding, CA
Rail Community
