I need to export points from my corridor. One of the subassemblies is ShoulderVerticalSubbase. The outside point of the shoulder subassembly has a point code EPS. The EPS code is one that I need to create points from.
When I try to Create Points from my corridor, I can select Point Codes from a a list of 22. EPS is not in the list (see image). How can I create those points?
In case it matters: this corridor was created with Civil 3D 2009. I'm now using it in Civil 3D 2012.
Solved by tcorey. Go to Solution.
Is your corridor set to display a featureline at the EPS points?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
If you have an EPS featureline in your corridor then you should be able to create points along it. As a workaround try extracting the featureline from the corridor and then create points from that.
Steve
Try replacing the 2009 version of the Subassembly with a modern version. I tested in 2015 and the point is available for extraction.
