Civil 3D Forum
Create curb return profile
6 REPLIES 6
ds1qmk
2211 Views, 6 Replies
Hi all
I try to make curb return profile without profile view like a intersect command.
I was make curb return alignment but I can not find profile command without profile view
I wonder someone advise to me.
Regard
6 REPLIES 6
Jeff_M
in reply to: ds1qmk
Why not create the profile view? Just create it, assign elevations based on the range you will need, then draw the profile.
gccdaemon
in reply to: Jeff_M
You could also edit the alignment, then click pick sub-entity, then add Z elevations on the "Pass through points".
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
ds1qmk
in reply to: Jeff_M
Thanks for your advise
ds1qmk
in reply to: gccdaemon
Is that possible?
In case of fixed line (I was convert polyline to alignment)
1. I was select edit alignment geometry
2.  Click alignment grid view
3. Click Sub-Entity editor (Blank alignment layout parameter is shown)
4. Choose alignment entity in grid view then alignment layout parameter box shown alignent.
5. Click Pass through point1 & 2 and modify end of number
    (212884.9529m,377135.6833m,0.0000m) to (212884.9529m,377135.6833m,32.0000m)
6. but Pass through point 1&2 number is not change
Do I miss something?
gccdaemon
in reply to: ds1qmk
Don't do the grid view. If you're using 2011, do this:
1. Alignments>Edit Alignment Geometry>Pick the alignment
2. Pick Sub-Entity>Pick line or curve in the alignment
3. Click the "Sub-Entity Editor" Icon next to the "Pick Sub-Entity" is what will allow you to edit the Z value. Go to the geometry section and at the bottom you'll see Pass Through Point1, etc. From here is where you change the Z elevation.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Ajilal.Vijayan
I was trying the same steps to update the elevation ,but the values are not changing.
Its keep going back to 0.
Rail Community
