Valued Contributor
1 Kudo
Post 1 of 7
Create cross sections in a separate drawing
1038 Views, 6 Replies
11-22-2012 07:50 PM
I want to create cross sections in a blank drawing via a Data shortcut Project.
My intent is to keep my file size to a minimum. I can include surface, alignment and profile per data shortcut
but not my corridor. My corridor is 3000 feet long and when I do cross sections in the
same drawing, it runs real slow.
Thanks John Wilson
Xref the corridor drawing into the sections drawing. You still need the alignment Dreffed, and possibly the surfaces, but the corridor will be picked up through the xref.
You can also create the crosssections in three separate files say 1000 feet each. Just dref the alignment and the design profile and xref the corridor in each file. No need to dref surfaces c3d will extract them from your corridor file.
920 Kudos
Post 2 of 7
Re: Create cross sections in a separate drawing
11-22-2012 08:40 PM in reply to: johnwilson0805
Valued Contributor GZE
Valued Contributor
5 Kudos
Post 3 of 7
11-22-2012 10:04 PM in reply to: johnwilson0805
Humphrey GZE
Civil 3D 2013 64bit SP1
Elitebook 8540w
Core i7 2.8GHz, 8Gig RAM
NVIDIA Quadro FX880
160Gb SSD
267 Kudos
Post 4 of 7
11-23-2012 09:21 AM in reply to: GZE
No need to bring in your profile for cross sections either as cross sections don't care about profiles.
Brian Hailey
CAD-1.com
My Blog
Valued Contributor
1 Kudo
Post 5 of 7
11-24-2012 07:57 AM in reply to: Jeff_M
Thanks Jeff it works great That what others have said too
Valued Contributor
1 Kudo
Post 6 of 7
11-24-2012 07:58 AM in reply to: BrianHailey
Thanks Brian. I learned alot. it works great
Valued Contributor
1 Kudo
Post 7 of 7
11-24-2012 08:00 AM in reply to: GZE
Thanks Humphrey
It sure saves me time it runs fast
