Can you create a cropped Surface from a Surface created by pasting Dreffed Surfaces.
I get an "Error creating cropped surface" message each time I try. The command line looks like this:
Command: CREATECROPSURFACE
Select first corner or [Object/Polygon]: O
Select objects: 1 found
Select objects:
Select point in the area to crop:
Point (616864.92,861180.44,0.00)
The Point is the point I picked inside the closed polyline I pick as an Object. The boundary of that area highlights showing it has accepted that as the cropping boundary. I have also tried tracing the polyline point by point. The command line then shows all the points I picked.
Working in 2014 SP-1.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Solved by MikeEvansUK. Go to Solution.
@Neilw wrote:
I haven't tried Allens suggestion of pasting a paste into a new surface.
Well. It was really Mikes suggestion. I just confirmed it works. I now have a cropped Surface in a new drawing. From reading Help on the subject of Cropped Surfaces. It looks like there is still a link to the original surface but it doesn't work quite like a Dref. Also, since the cropping takes place from a pasted surface. You might have to go back a couple Surfaces and then bring any edits forward to initiate a change in the cropped Surface. I haven't tired it.
Allen
Allen Jessup
@doni49 wrote:
It hadn't sunk in that you were promoting it -- in essence removing the dynamic link.
Thanks for helping me understand and sorry for hijacking your thread.
I'm not technically promoting. Only pasting into what we've been calling the dummy surface. A pasted surface should maintain a link to the original surface. I haven't figured out what the double pasting and cropping will do. Help suggests that a link is maintained between the cropped Surface an the Surface it was cropped from. Not exactly a Dref. I did notice that in the new drawing that not only was the cropped Surface create. But some of the original small Surfaces that the crop line crossed were also created in the new drawing. That makes me think that if the original smaller Surfaces were edited, the cropped Surface would be updated. I haven't tried that yet.
No problem about hijacking. We're all talking about the same thing and trying to learn. Besides. In some circles EE's are notorious for hijacking threads.
Allen
Allen Jessup
My goal was to create a Cropped Surface from a large Surface that had been created by pasting in Dreffed Surfaces. I now want to paste in a Surface created from field work.
While ending up with a Surface linked to the original Surfaces would be nice. In this case it was unnecessary because the Lidar data wont change. So even a static Surface is fine for my use.
Allen
Allen Jessup
I tried it and got an edit to follow through all the iterations except to the cropped surface drawing. While this doesn't provide a dynamic link through the whole process. It would only require the recreation of the final cropped Surface to show an edit to an original surface.
Allen
Allen Jessup
And yet I don't long for the days of Alidades, Statia and Plane Table (1995)
