Civil 3D Forum
Create Cropped Surface from Dref?
29 REPLIES 29
Message 1 of 30
AllenJessup
2566 Views, 29 Replies
Can you create a cropped Surface from a Surface created by pasting Dreffed Surfaces.
I get an "Error creating cropped surface" message each time I try. The command line looks like this:
Command: CREATECROPSURFACE
Select first corner or [Object/Polygon]: O
Select objects: 1 found
Select objects:
Select point in the area to crop:
Point (616864.92,861180.44,0.00)
The Point is the point I picked inside the closed polyline I pick as an Object. The boundary of that area highlights showing it has accepted that as the cropping boundary. I have also tried tracing the polyline point by point. The command line then shows all the points I picked.
Working in 2014 SP-1.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
29 REPLIES 29
Message 2 of 30
in reply to: AllenJessup
I believe I have seen an error in the past because the UCS was not set to world. You might varify that it is set to world before you try to crop.
Message 3 of 30
Neilw_05
I've never been able to clip a surface made from pasted DREF's. I'm pretty sure it can't be done. Sorry for the bad news.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 4 of 30
AllenJessup
I had read about that. But that's not the problem in my case.
I'm almost thinking I'll have to go back and crop each original surface individually then Dref and paste them together.
Allen
Allen Jessup
Message 5 of 30
AllenJessup
in reply to: Neilw_05
It would be nice if that were covered in help or the error told you it can't crop a Dref.
Allen
Allen Jessup
Message 6 of 30
Sorry Allen, I was not able to do it either. My previous suggestion was based on what I thought I had read on the forums.
Message 7 of 30
MikeEvansUK
You can create a "dummy surface" and paste the dreffed surface into it then crop from that one.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 8 of 30
Neilw_05
in reply to: MikeEvansUK
As I mentioned earlier, I can't get that to work. Have you tried it Mike?
WIN 10 64 PRO
Message 9 of 30
Neilw_05
I've concluded there are 3 parts to a learning curve:
1) What do the tools do
2) How can you apply them to meet varying scenarios
3) What are their deficiencies and limitations
Unfortunately parts 2 and 3 are learned largely through trial and error and a lot of time researching workarounds.
WIN 10 64 PRO
Message 10 of 30
AllenJessup
Mike is right. If you create a New Surface and paste the composite Surface that was created by pasting the Drefs in to. Then you can Crop the New Surface. This is the way it would work.
  1. Dref Surfaces
  2. Create the first new Surface
  3. Past the Dreffed Surfaces into the first new Surface
  4. Create the second new Surface
  5. Paste the first new Surface into the second new Surface
  6. Crop the second new Surface
That results in a new drawing with the cropped Surface.
Allen
Allen Jessup
Message 11 of 30
doni49
I'm curious what is different about CROPPING a surface vs applying an OUTER BOUNDARY.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 12 of 30
Neilw_05
in reply to: doni49
An outer boundary only limits the extent of the triangles when you build the surface. All of the data is processed first, then the boundary applied.
A crop (clip) actually limits the data that is used to build the surface. It is a better way to manage a large dataset as it reduces processing.
WIN 10 64 PRO
Message 13 of 30
AllenJessup
Exactly why I wanted to use it!
Allen
Allen Jessup
Message 14 of 30
MikeEvansUK
Yes I tied it on a surface before I posted. First time I have used that command. Only just crossing over to 2014 in production env now we have a service pack.
Sorry it wasn't clear what you meant earlier. I use the dreffed pasted surface workaround all the time to edit the surface (trim back or expand etc) without effecting the original.
I figured it would work here as well.
Mike Evans
Message 15 of 30
doni49
Hmmm.  if that's the case, then I don't understand how it would be helpful to paste the surface in to a new surface and then crop the new one.
When you paste one surface into a new one, doesn't it read the WHOLE pasted surface?  Wouldn't the crop happen to the resulting surface?  It sounds like that would just make for twice as much data to process.
Don Ireland
Message 16 of 30
MikeEvansUK
in reply to: doni49
I think you are missing the point. The whole surface definition is not taken through to the cropped surface. Only the extents of the crop are.
Creation of the cropped surface is on new or existing file and using workaround of pasted dreffed surface is only to assist in this creation from dreffed surface. Following cropping the pasted surface can be deleted.
Obviously you can just promote the surface, crop and undo the promotion to achieve the same result.
Mike Evans
Message 17 of 30
Neilw_05
in reply to: doni49
I'm not sure about how the software handles DREF'd surfaces. All I know is I can't clip a DREF'd surface. If C3D can clip a DREF then it certainly has a useful purpose. As in Allen's case we have a very large coverage. If we want to utilize pieces of that large surface we could DREF it and clip it to where we need it.
I haven't tried Allens suggestion of pasting a paste into a new surface.
WIN 10 64 PRO
Message 18 of 30
doni49
Ok thanks -- just trying to understand this.  I always thought that when you pasted a suface into another surface the ENTIRE source surface would be processed.  And I didn't think it would look at the cropping until after the paste.
I like learning new stuff!  🙂 I can certainly see how something like this would be useful.
Don Ireland
Message 19 of 30
AllenJessup
in reply to: doni49
The entire Surface does come through to the Surface it's pasted into. The point of the operation is that you can't create a cropped Surface from the Surface you've pasted the original Dreffed Surfaces into. Once you've pasted the composite Surface into an new "dummy" Surface. You can create a cropped surface.
So to end up with a cropped Surface you first have to paste all the smaller Surfaces together. Then you need to paste that large Surface into the dummy surface. That creates another large Surface. Then you can crop that version of the large Surface to get a smaller Surface to work with.
Also the cropped surface doesn't end up in the drawing you're working in. You have to select or create another drawing to create the cropped surface in. The cropped surface behaves like a Snapshot.
Allen
Allen Jessup
Message 20 of 30
doni49
Ahhhh.  That's the part I was missing.  When I DRef a surface, I usually leave it dynamically linked to the source.  It hadn't sunk in that you were promoting it -- in essence removing the dynamic link.
Having read your latest post, I went back and re-read some of your earlier posts in this thread.
Thanks for helping me understand and sorry for hijacking your thread.
Don Ireland
Rail Community
