AllenJessup
Message 1 of 30 (432 Views)
Create Cropped Surface from Dref?
432 Views, 29 Replies
11-20-2013 06:37 AM
Can you create a cropped Surface from a Surface created by pasting Dreffed Surfaces.
I get an "Error creating cropped surface" message each time I try. The command line looks like this:
Command: CREATECROPSURFACE
Select first corner or [Object/Polygon]: O
Select objects: 1 found
Select objects:
Select point in the area to crop:
Point (616864.92,861180.44,0.00)
The Point is the point I picked inside the closed polyline I pick as an Object. The boundary of that area highlights showing it has accepted that as the cropping boundary. I have also tried tracing the polyline point by point. The command line then shows all the points I picked.
Working in 2014 SP-1.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
You can create a "dummy surface" and paste the dreffed surface into it then crop from that one.
Valued Mentor
dmartin
Message 2 of 30 (426 Views)
Re: Create Cropped Surface from Dref?
11-20-2013 07:05 AM in reply to: AllenJessup
I believe I have seen an error in the past because the UCS was not set to world. You might varify that it is set to world before you try to crop.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
Neilw
Message 3 of 30 (422 Views)
11-20-2013 07:11 AM in reply to: AllenJessup
I've never been able to clip a surface made from pasted DREF's. I'm pretty sure it can't be done. Sorry for the bad news.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
AllenJessup
Message 4 of 30 (421 Views)
11-20-2013 07:11 AM in reply to: dmartin
I had read about that. But that's not the problem in my case.
I'm almost thinking I'll have to go back and crop each original surface individually then Dref and paste them together.
Allen
AllenJessup
Message 5 of 30 (420 Views)
11-20-2013 07:13 AM in reply to: Neilw
It would be nice if that were covered in help or the error told you it can't crop a Dref.
Allen
Valued Mentor
dmartin
Message 6 of 30 (409 Views)
11-20-2013 07:24 AM in reply to: AllenJessup
Sorry Allen, I was not able to do it either. My previous suggestion was based on what I thought I had read on the forums.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
mikeevans
Message 7 of 30 (408 Views)
11-20-2013 07:25 AM in reply to: AllenJessup
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Neilw
Message 8 of 30 (393 Views)
11-20-2013 07:51 AM in reply to: mikeevans
As I mentioned earlier, I can't get that to work. Have you tried it Mike?
WIN 7 64 PRO
RADEON 6450, 1 GB
Neilw
Message 9 of 30 (391 Views)
11-20-2013 07:55 AM in reply to: AllenJessup
I've concluded there are 3 parts to a learning curve:
1) What do the tools do
2) How can you apply them to meet varying scenarios
3) What are their deficiencies and limitations
Unfortunately parts 2 and 3 are learned largely through trial and error and a lot of time researching workarounds.
WIN 7 64 PRO
RADEON 6450, 1 GB
AllenJessup
Message 10 of 30 (385 Views)
11-20-2013 08:04 AM in reply to: Neilw
Mike is right. If you create a New Surface and paste the composite Surface that was created by pasting the Drefs in to. Then you can Crop the New Surface. This is the way it would work.
  1. Dref Surfaces
  2. Create the first new Surface
  3. Past the Dreffed Surfaces into the first new Surface
  4. Create the second new Surface
  5. Paste the first new Surface into the second new Surface
  6. Crop the second new Surface
That results in a new drawing with the cropped Surface.
Allen
