Member
rosiah
Message 1 of 8 (278 Views)
Create corridor surface for loop road.
278 Views, 7 Replies
05-05-2014 08:44 PM
Hye all, I really need some help. I'm currently working on road design where my road is a loop. I already managed to create the corridor, however when I tried to generate the surface, it seems that at wherever the feature lines intersecting each other, the surface will turn out funny. I also already tried to use the 'split region' but still failed to produce proper surface. See the attach pictures for better understanding. Thank you in advance.
Member
rosiah
Message 2 of 8 (273 Views)
Re: Create corridor surface for loop road.
05-05-2014 08:54 PM in reply to: rosiah
Sorry if some of you couldn't find the attachment.
Active Contributor
xujjjan
Message 3 of 8 (251 Views)
05-06-2014 04:54 AM in reply to: rosiah
And where can I see your attachment?
Member
rosiah
Message 4 of 8 (220 Views)
05-08-2014 10:50 PM in reply to: xujjjan
It seems that I cant upload any attachment. The problem is, when I tried to generate the surface from corridor, it seems that at stretch where my road is intersecting with each other, the surface will triangulate the upper and lower corridor, thus making my surface become haywire. This is also reflected in my cross-section. I already tried to assign outer corridor as boundary and assign split region during generating the corridor but nothing change. Really hope that my explanation is clear enough. Please, please help me. :smileysad:
sboon
Message 5 of 8 (200 Views)
05-10-2014 11:21 AM in reply to: rosiah
You cannot create any surface in Civil3d with two elevations at the same x,y coordinate.  You would have to create two surfaces for this.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Member
rosiah
Message 6 of 8 (155 Views)
06-08-2014 08:58 PM in reply to: sboon
How to create 2 surface for the same corridor? Do I have to create different corridor?
sboon
Message 7 of 8 (152 Views)
06-08-2014 09:15 PM in reply to: rosiah
You can create two surfaces in one corridor and separate them using boundaries.  You need to use feature lines to define the boundary.
Once the boundary has been created you will need to adjust the station range.
Distinguished Mentor
Pointdump
Message 8 of 8 (135 Views)
06-09-2014 01:16 AM in reply to: rosiah
R,
A loop road with an upper and lower corridor? I'm having a tough time picturing that.
In a loop corridor, you should always try to start and end in the middle of a straight segment. And the start and end elevations have to be the same. Like using a corridor for pond grading.
Dave
Dave
Mohave Valley, Arizona
HP DV7 Laptop
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014
