Civil 3D Forum
Create copy of lowered surface
5 REPLIES 5
kgrover
2590 Views, 5 Replies
Is there a way to create a copy of a surface that was lowered?? For example, we have an original ground surface, and drop it by 0.3 to get a rough stripped surface. However, I want to keep the original ground surface, and then create a new stripped surface.
Right now we export landxml and reimport and rename. Just looking for a way not to have to do this.
Kevin
5 REPLIES 5
Joe-Bouza
in reply to: kgrover
No no no...
Make a new surface "OG lowered x", paste OG into it and lowere that surface. now if OG gets updated the lowering is dynamic. eazy peezy
Your Name
jasonp
I always just use the AutoCAD Copy command to copy the original surface and put it back in the same spot then raise or lower one of them.  Hope this helps.
AllenJessup
I've never done it with a lowered surface. But according to 2014 help, a regular copy should work on a surface.
Copying a Surface
Create a copy of an existing surface.
When a surface is copied, the copy is named using a naming convention. For example if the original surface that is copied is named ‘Surface 1’, the new surface is named ‘Surface 1 (1)’. If Surface 1 is copied again, the new surface is named ‘Surface1 (2)’. If ‘Surface 1(1)’ is copied, the new surface is named ‘Surface 1 (1) (2)’.
To copy a surface
  1. In the drawing area, select the surface, right-click, click Basic Modify ToolsCopy.
  2. At the command line, you are prompted to specify a base point for the surface.
  3. Pick an insertion point in the drawing area.
    The surface is copied in the drawing and added as a new surface to the Prospector tree.
  4. To edit the name of the surface, right-click the surface in the Prospector tree and click Properties.
    The Surface Properties dialog box is displayed with the Information tab active. The Name field contains the name of the copied surface, which is, by default “ <surface-name> (1).”
  5. Enter a new name in the Name field.
  6. To edit the description of the surface, enter a new description in the Description field.
  7. To change the style that the surface is using, select a style from the Object Style list or use the standard style selection controls.
  8. Click Apply to make the changes, or click OK to make the changes and close the Surface Propertiesdialog box.
Allen Jessup
CAD Manager - Designer
kgrover
in reply to: Joe-Bouza
Thanks, this works great!
Kevin
Joe-Bouza
HTH
Your Name
Rail Community
