Hi, I have polyline for which I want to create a number of points at equal intervals (as well as a few specific locations). I then want to export the points to Excel with the x,y coordinates as well as the chainage distances from.
I've tried creating an alignment and then using create points/measure at to create the points - works well. But I'm stuck on how to add the chainage distance into the point descriptions How do I do it?
- Mick
Solved by Jeff_M. Go to Solution.
- Mick
In the Create Points settings, Points Creation->Prompt for Descriptions=Automatic-Object
This will add the alignment name and station to the point's description.
Thanks Jeff, that does it - so simple!
Is it possible to customise the automatic description? I get points labelled as CL-1 450.344, whereas I'd like to get rid of the CL-1 prefix and convert the chainage to km instead of m (with less decimals)... The work around that I have now is just to export to excel then clean it up there, but it would be nice to get the output directly for c3d
Regards
- Mick
No garauntee but thet label composer probably has settings for that
Your Name
Your Name
I don't know of any way to affect the Automatic Description...it uses the Alignment Name & Station/Chainage. To chnage the staion units, set the drawing's ambient setting for Station to kilometer. To remove the Alignment name you should be able to use the method I outline here: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Edit-Point-Descriptions/td-p/5046776/jump-to/...
How to Chainage Mark in Autocad, along with center line (RHS and LHS should be chosen by us). and tick should be the arrow line. i have attached the sample screen shot, please help me for this.
