Valued Contributor
asloat
Message 1 of 5 (170 Views)
Create alignment from object results in wrong length
170 Views, 4 Replies
09-17-2013 06:36 AM
I am working on creating an alignment from a single polyline. The polyline, which was originally created in Carlson 2012, is a flat polyline that is about 1200 feet in length. When I select it with create alignment from object, it accepts it and seems to work. For some reason though, the stationing is way off  --- e.g. the true 50' mark is showing up as 0+04.17 which results in an end station of 0+99.31 on a 1191' polyline.
edit> I also have tried this with a brand new polyline I created in civil3d, same issue.
It looks like you are off by a factor of 12. Check your units and make sure you are starting with a Civil 3D template.
Peter Funk
I went through and recreated everythign from scratch and it seems fine now. I think i may have utilized an architectural template at some point. thank you.
jmayo
Message 2 of 5 (165 Views)
Re: Create alignment from object results in wrong length
09-17-2013 06:49 AM in reply to: asloat
Can you post a file with the polyline?
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Employee
peterfunkautodesk
Message 3 of 5 (160 Views)
09-17-2013 06:56 AM in reply to: jmayo
Peter Funk
Peter Funk
Valued Contributor
asloat
Message 4 of 5 (148 Views)
09-17-2013 07:24 AM in reply to: peterfunkautodesk
Employee
peterfunkautodesk
Message 5 of 5 (141 Views)
09-17-2013 07:27 AM in reply to: asloat
When I see a post about things being the wrong size I'll divide the two number and typically the are either off by 12, 0.83333, ~3 or ~0.333. Mixing units is pretty easy to do.
Cheers,
Peter Funk
Peter Funk
