Back in LDD sections were simple. I would create my typicsal secitons with several datums representing finished ground, sub base, excavated surface etc.
In my c3d model I have creted my typical assembly for finished grade and it works great. Our site is alomost all bedrock that requries blasting and now I want to create a second "datum" for my corridors so I can calculate blating quanities for my entire site. its in the order of 250 000 cu.m. of blast so this is important. I know there are a hundred ways of doing this and there is probably a better way. However I have to work within my familiar skillset to actually get things done aswell. All I need to get out of this are cogo points for my new datum into mydrawing so I can merge them with the points I have already created for the non corridor areas. Then voila, I have my blasted surface that I then can use to calculate a volume surface.
What I need is some guidance on creating this second datum. See the attached image where i show my assembly, finished ground subassemblies and below the second datum(or sub assembliy) I need.
Many Thanks
Solved by mathewkol. Go to Solution.
Ok so I created another corridor for my blast surface starting ith a new assembly, then add a vertical link to get down to my reference point on my blast surface, then used two linkmulti for left and right to create the surface/datum i needed. I now have points created for my finished ground centerline that need to be filtered out when bringing in points. I do alot of this sort of thing and would really like to hear of any better methods. I would really like one assembly with multiple datums.
Depending on the level of detail in your sub assemblies, it may be possible to create mutliple surfaces from one corridor.
For example, with a generic pavement structure for a roadway, you can create an Finish Grade surface using the Top Link from you assembly and a Subgrade surface using the bottom link of the granular material. This way, both surfaces are tied to the same corridor and will both update with any edits to the corridor.
