Civil 3D Forum
Create a profile from a series of points
6 REPLIES 6
2513 Views, 6 Replies
Dear all,
I am new to Civil3D and I want to ask you the following:
I have collected points across a 500m distance with easting, northing and height values. This line of points is measuring a stepped slope of a field.
I want, if possible, to create a profile (something that looks like a slice of the slope, so that the steps and profile of the slope is clear.
Can this be achieved? Will you be able to guide me through the process?
Thank you for your help.
6 REPLIES 6
Joe-Bouza
It will only be good as your data set. And you will need the station baseline to go with it
Home>> Profile>> profile from file.
check the required format
should be ASCII comma or space and looks like
station, eleavation
Joe Bouza
sboon
Normally Civil3d profiles are made from surface data, but it sounds like you just have a single line of points that you want to use.  It can be done but the process is a little different than normal.
Do you want the profile to go exactly from point to point, or do you want a straight line across the slope and then project the points onto that?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Jay_B
Here's a Civil Intentions blog on creating a Profile from a linear set of points where you have no surface to sample.
http://civilintentions.blogspot.com/2012/08/creating-profile-from-single-line-of.html
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: sboon
Thank you for your reply. I will like the profile to go from point to point.
Joe-Bouza
in reply to: Jay_B
Thats cool but I'd skip the 3d transparent>> FL >> excel and go straight to alignment>> sta off >> excel
Joe Bouza
KirkNoonan
1. Create an alignment through your points.
2. Create a blank profile view, ensure that the profile view has elevations set to the range of your points.
3. Create a profile using the tangents tool from the profile creation tools tool bar.
4. Using the Profile Station and Elevation from COGO Point transparent command (see image), select the points to create the profile.
Rail Community
