trying to print preview certain drawings causes civil 3d to crash. Didn't make any significant changes from a few days ago, and it was working fine then. I get the following error:
Fatal Error: Unhandled c0000409h Exception at edd52bc0h. Googled the error, does not come up on the search.
Tried fixing it by AUDIT and PURGE.
>> narrowed it down that it is just plotting to pdf that causes this
what PDF driver did you use?
If you have used the "DWG to PDF.pc3" ... have you migrated data from older Civil 3D releases?
- alfred -
