Civil 3D Forum
Crashing during Wblock or Copyclip
12 REPLIES 12
Message 1 of 13
rkmcswain
1873 Views, 12 Replies
C3D 2011 / Update 2
I have noticed about a 50/50 chance of crashing when using Copyclip or Wblock, and the selection includes C3D objects (feature lines, etc.). Sometimes when I Wblock out, no file is written, then if I try to repeat it, there is about a 99% chance that is will crash on the repeat try.
Anyone else notice this?
I found one old similar thread with no replies.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/C3D-2009-wblock-crashing/m-p/2386700
Tags (3)
12 REPLIES 12
Message 2 of 13
in reply to: rkmcswain
I too had the same problem... was wblocking a group of profiles and would get a not responding message from Civil 3d 2012.   I tried a fourth time and waited for bout 10 minutes and it worked.      So maybe it's not an issue opther than it takes a while... I'll switch to decaf!
Message 3 of 13
Karen_Dowling
I would be interested in speaking with you about your crashes.
Are you sending in Customer Error Reports?
Would you be able to send me a file that I could reproduce your issue with?
Let me know...
Karen Dowling
Sr QA Analyst,
Autodesk, Inc.
Karen Dowling
Sr. Quality Analyst
Autodesk, Inc
Message 4 of 13
neilyj666
in reply to: Karen_Dowling
Removing Xrefs before Wblock has worked for me in the past
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 13
Hi Karen,
Any chance you could help me out with a similar problem?
Here's the thing, I'm using AutoCAD map 3d 2012, and when I copyclip something from a one file to another, CAD crashes. I don't think that this has anything to do with the ammount of information I'm trying to copy (ex: lines, plines, hatch, blocks and text), since I've copied bigger ammounts of information in earlier versions and it worked peferctly.
Any help form anyone is more thean welcome!
Paulo
Message 6 of 13
I've justo noticed in one of many attempts to copyclip the selection to another drawing file that CAD only crashes when the lineweight display is on, otherwise it manages to copy (dispite being a slower process than earlier versions) and paste in other files.
May this be a bug in CAD map 3d 2012???
Message 7 of 13
Karen_Dowling
Hi Paulo,
Absolutely, I am installing Map 3D 2012 right now and will attempt to Copyclip with the lineweight display on.   I tried this in Civil 3D 2012 (built on Map) and I can copy paste with Lineweight display on without issue (using a simple pline).
Possible for me to get hold of the file you are using and point me to the entity you are messing with?
karen.dowling@autodesk.com
Thanks!
Karen
Karen Dowling
Sr. Quality Analyst
Autodesk, Inc
Message 8 of 13
I amexperiencing the same issue in Civil 3D 2013 (both with or without service pack).
Message 9 of 13
I keep getting the same fatal error at the end of a wblock. It says:
FATA ERROR: Unhandled Access Violation REading 0xfffffff Exception at 30e3c3b9h.
I've tried removing all X-refs and reinstalling AutoCAD Civil 3D 2016 and still get same issue.
Could really use some help with this one.
Tags (2)
Message 10 of 13
Karen,
Did you ever find a resolution to this? I'm still having problems. Now it's copy/clip too.
Trip
Message 11 of 13
Renbrig
This needs to be resolved.  I am still crashing every time I try to take one thing from the file I am working in and put it into another file.
Message 12 of 13
in reply to: Renbrig
I am experiencing the same problem.
Any solution or denial of this issue?
Message 13 of 13
I don't know if this'll help, but try giving it a shot. Save a copy of the file you want to copy from, clean it up from all the elements that you don't need to export to another file, use purge command to clean of all unnecessary data, and save again.
Try copying from the new file created.
Hope this help's!
Paulo Caldas
Rail Community
