Matt,
Try setting Proxygraphics to 0. There is an issue which we are tracking
related to Proxygraphics set to 1. If that does not work, send me an email
danieldotphilbrickatautodeskdotcom. I'll let you know how to get the
drawing to me.
Dan
wrote in message news:5162175@discussion.autodesk.com...
I am just at my wit's end here. I have a drawing that I have had a good
amount of trouble with and have recreated several times. The project is
finally finished and submitted but I no longer can make any changes to the
file and successfully save it. In fact, whenever I open the file and attempt
to save it, Civil 3D crashes out with a Fatal Error. I have tried running an
audit and some basic errors are fixed however a save still causes a crash. I
have been able to successfully restore the file from the server to a file
from last week and open it and save it just fine, however, after opening and
saving in 2007 format, the next time I open and save it crashes again. My
question, is this a 2007 issue? Do I simply continue to use 2006 to avoid
this issue? Any thoughts?
