Hello all. I have one request about surface spot elevation. when i put spot elevetions on minor contours they have same elevation 22.12 , but when i make contour smoothing they are changing. for example 22.12, 22.13, 22.08, , So,, what is reason can you help me? thanks advance..
Are you using Contour Smoothing or Surface Smoothing?
Here's a quote from my old boss that helps with dealing with these discrepancies:
"All Contours are lies".
Allen
Allen Jessup
CAD Manager - Designer
John Mayo
If you MUST have spot elevation labels directly on the contour lines. You'll have to use Surface Smoothing which does alter the Surface by inserting interpolated points. The Surface wont be any better or worse but the contours will look smoother. This will also increase the size of your Surface.
Allen
Allen Jessup
As others have already said, the way to make the contours match your data most closely is to use unsmoothed contours.
Is there a reason you don't use contour labels on the contours? These will show the same value that the smoothed contour represents.
If you must use Spot Elevations, even if you smooth the surface, don't smooth the contours or you'll have the same issue, maybe less so, but it won't go away completely.
If you care to entertain another workaround: Smooth the contours, extract the smoothed contours, make a surface from the extracted contours. It won't match the previous surface exactly, but the spot elevations will match the contours.
You could create a Surface from contours as Tim outlined. Then use that Surface only for the labels. Keep the original Surface for everything else.
Allen
Allen Jessup
