Civil 3D Forum
Counting Parking Spaces
9 REPLIES 9
Message 1 of 10
8792 Views, 9 Replies
I came across a tip/trick on how to count/label parking spaces using dimensions, I think, awhile back. Now that I need to do that for a parking lot design, I can't find it. Does anybody know what I'm talking about?
Thanks in advance for any and all help.
Scott O.
Civil 3D 2007, 2008
Anchorage, AK
9 REPLIES 9
Message 2 of 10
Hmm does a block not work for you?
You can then add attributes to distinguish between types and export a table of results.
Message 3 of 10
You could use a line label with an expression to divide length by width.
Then just put the line on a no-plot layer. You'll have to play with the
rounding to make sure it works, but that's the one I've used.
HTH
James Wedding, P.E.
Engineered Efficiency Inc.
www.eng-eff.com
www.civil3d.com
C3D/Vista/2GB
Message 4 of 10
are you saying make a block to the parking stall size and lay that out? That might work, thanks.
Scott O
C3D 2007, 2008 (in transition in the office)
Anchorage, AK Message was edited by: olsonscottm
Message 5 of 10
Thank you Mr. Wedding, that is going to work just fine. I was hoping to use a label so I wouldn't have to futz with different text sizes.
Man, I love C3D!! Just wish I was smart enough to harness a fraction of it's power, but I'm getting better.
Scott O.
C3D 2007, 2008 (in transition)
Anchorage, AK
Message 6 of 10
I've been using a simple AutoCAD dimension style. I set the measurement scale to 1/parking stall width. (ie, a 9' stall width = 1/9 measurement) I do my dimensioning through an active view port so I don't need to make any adjustment to the style for different scales. It's simple, and adaptable, so it works fine for me.
Message 7 of 10
Thanks, I think that was what I was thinking of when I posed the question.
I've since taken Mr. Wedding's idea and made a line label with an expression which worked out great.
However, I will keep that little nugget in the back of my mind for future reference.
Scott O
Anchorage, AK
Message 8 of 10
You can also use the dims and/or labels to count CMU's/course in profiles by
dividing the area by block width.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5696594@discussion.autodesk.com...
reference.
Scott O
Anchorage, AK
Message 9 of 10
matthew.risch
Any ideas on how I can remove the brackets from displaying when using Alt. Units to add additional information to the dimension?
Message 10 of 10
allen
I was just reviewing old notes here when I came upon your post. can you tell me how I can use blocks to generate database or some sort of chart; keeping track of parking lot counts?
Thank you very much
Rail Community
