AutoCAD Civil 3D General Discussion
*Expert Elite*
AllenJessup
Message 1 of 13 (246 Views)
Accepted Solution
Count Styles
246 Views, 12 Replies
11-06-2011 01:39 PM
Is there a way to determine the number of styles in a drawing?
Allen
C3D 2010
Dell M6500, Win 7 Pro, 8GB RAM
AFAIK not with 2010 (without dev).
With Civil3D2012 you have a command _PURGESTYLES that shows a number (of purgeable) styles plus copy&paste of the list is supported. Maybe this is a help.
- alfred -
*Expert Elite*
Alfred.NESWADBA
Message 2 of 13 (245 Views)
Re: Count Styles
11-06-2011 01:54 PM in reply to: AllenJessup
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
AllenJessup
Message 3 of 13 (242 Views)
Re: Count Styles
11-06-2011 02:18 PM in reply to: Alfred.NESWADBA
Thanks. I'll give it a try.
Allen
*Expert Elite*
AllenJessup
Message 4 of 13 (240 Views)
Re: Count Styles
11-06-2011 02:20 PM in reply to: Alfred.NESWADBA
_PURGESTYLES gives me 552 styles. So I'll go with that  for now. Thanks.
Allen
*Expert Elite*
AllenJessup
Message 5 of 13 (229 Views)
Re: Count Styles
11-06-2011 02:46 PM in reply to: Alfred.NESWADBA
It looks like there are about 70 unpurgable standard styles that won't show in that list. But it's a good start.
Allen
*Expert Elite*
Alfred.NESWADBA
Message 6 of 13 (227 Views)
Re: Count Styles
11-06-2011 02:50 PM in reply to: AllenJessup
Hi Allen,
sorry, I have never did a check of this number. And as the count is for purgeable styles then the "Standard"-styles will not be counted within that group.
I find it interesting how you got the number 70 that fast - without having an option to count anything in another way yet :smileywink:
- alfred -
Alfred NESWADBA
*Expert Elite*
AllenJessup
Message 7 of 13 (195 Views)
Re: Count Styles
11-07-2011 05:04 AM in reply to: Alfred.NESWADBA
Hello Alfred,
I used the old manual guesstimate method. I started a drawing with no template then used the purgestyles command. After that I'm left with a Standard style for each item that uses a style. I expanded each item in the prospector and counted how many times I saw Styles. I got just under 70 and rounded up.
Thanks for the help!
Allen
*Expert Elite*
mathewk
Message 8 of 13 (185 Views)
Re: Count Styles
11-07-2011 06:35 AM in reply to: AllenJessup
Curious, why would you need to know the total number of styles in a drawing.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
*Expert Elite*
AllenJessup
Message 9 of 13 (178 Views)
Re: Count Styles
11-07-2011 07:26 AM in reply to: mathewk
I need to give an estimate of the time to revise them.
Allen
Active Member
MatthewHeal83
Message 10 of 13 (122 Views)
Re: Count Styles
09-06-2013 09:21 AM in reply to: AllenJessup
The purge command only gives you the unused styles, there are styles embedded in the command settings that are considered "used" styles and will not show up in that list that represent a significant percentage of the total styles.  If you have a fully customized template you could be looking at missing out on several hundred styles.
I, too, am looking for a way to count the styles as part of some purge testing I'm doing.
Need installation help?
